'64 Cuda
I didn't know whether to put this here or in the Tires & Rims section, but I'll start here.
Can anybody tell me if switching from either 9" or 10" front brakes to the Kelsey-Hayes 4 Piston brakes moves the mounting surface of the wheel in or out from its previous position? I'm wanting to know if front tire & rim clearances were marginal with one setup, will they be the same when switching to the discs, or will they change. Thanks!
:burnout:
:burnout:
