64-66 A-body SB V8 9.5 4 Spd Parts - $150 package
67-76 A-body SB V8 10.5 4 Spd Parts - $300 package
- Cast Iron SB Bell housing, all threads tapped, casting # 2806081 (for smaller 9.5 flywheel) 64-66 AB 273 - $75
- 1963-66 A-body Clutch/brake pedal assembly (missing the spring) - $65
- 9.5 122 tooth, 18 lb flywheel (needs to be turned), all threads tapped - $45
- Alum SB Bell housing, all threads tapped, casting # 2892482 for 10.5 flywheel) 69-71 ABC 273 - $75
- 10.5 130 tooth, 26 lb flywheel internal balance for 318/340 (needs to be turned), all threads tapped - $75 ea
- 1970-72 A-body Clutch/brake pedal assembly includes spring - $125
- Hurst Shifter w/ handle (needs rebuild) - $45
- 11 23 spline clutch disc, used but w/ good material - $25
- Lakewood blowproof steel bellhousing & scattershield for BB Mopar (383/400/413/426/440 lists new for $445, needs to be cleaned up - sell for $225 obo
- Inland shifter handle that I was going to modify to use for my A-body
