4 spd parts/packages & Lakewood
DartmanTampabay
St. Petersburg, FL
64-66 A-body SB V8 9.5” 4 Spd Parts - $150 package
  • Cast Iron SB Bell housing, all threads tapped, casting # 2806081 (for smaller 9.5 flywheel) 64-66 AB 273 - $75
  • 1963-66 A-body Clutch/brake pedal assembly (missing the spring) - $65
  • 9.5” 122 tooth, 18 lb flywheel (needs to be turned), all threads tapped - $45
67-76 A-body SB V8 10.5” 4 Spd Parts - $300 package
  • Alum SB Bell housing, all threads tapped, casting # 2892482 for 10.5 flywheel) 69-71 ABC 273 - $75
  • 10.5” 130 tooth, 26 lb flywheel – internal balance for 318/340 (needs to be turned), all threads tapped - $75 ea
  • 1970-72 A-body Clutch/brake pedal assembly includes spring - $125
  • Hurst Shifter w/ handle (needs rebuild) - $45
  • 11” 23 spline clutch disc, used but w/ good material - $25
Lakewood Bellhousing Big Block - $225
  • Lakewood “blowproof” steel bellhousing & scattershield for BB Mopar (383/400/413/426/440 – lists new for $445, needs to be cleaned up - sell for $225 obo
Inland shifter handle - $25
  • Inland shifter handle that I was going to modify to use for my A-body
All prices plus shipping from 33708
