[FOR SALE] 4 Speed & Engine Parts
71-440-Duster
Northern Cal
A Body Trans $750 not shipping.
Fidanza Billet Aluminum Flywheel brand new still in box from Summit Racing $450
Hayes clutch and disk set new $300
Aluminum bell housing with fork, boot and inspection plate nice condition $300
4 speed pedals $200 sold pending
Wiends Stealth small block intake sand blasted with no grinding $200
Compcams small block cam & lifter package new $250
Cam 20-600-4 dur @ 50 227 int 296 exh lift .486 int .473 exh
Lifters 822-16 Hydraulic
Compcams 2103 double roller timing set small block $75 SHIPPED!
Hydraulic pushrods new in box 16 quantity $50
273 mechanical rocker assembly w\banana grove shafts and all hardware $200
273 mechanical pushrods $75
I'm having trouble identifying the clutch PP/disc. Your description calls it a McCloud (I assume that is McLeod) but the tag calls it a Hayes (Hays?). Just what do you have, a manufacturer and PN would be handy. Thanks. :thumbsup:
Uh
Sorry, I’ve updated the item.
Updated price - Fidanza Billet Aluminum Flywheel 194361 130 tooth 10.5 inch flywheel. Brand new still in box from Summit Racing $350
Sold Wiend intake manifold, CompCams cam and lifters.
What is the balance on the flywheel? Neutral, external 360, external 5.9 magnum?
They flywheel part number is fidanza
194361​
Summit has it listed as either internal or external.
4 speed pedals are sold.
