[WANTED] 4 speed hump
Its not the greatest has a whole cut in the top I guess someone mounted a tachometer also have part of the floor board to use as a template if possible I used it as a template for mine just marked it about 1/2 less of a opening who ever cut this opening cut into the trans frame rail
This is how mine turned out using it as a template
