72ScampTramp
Scamp Tramp
What does it take to go 4 speed and a projected cost? What parts do I need? I have a 727 but a 4 speed would be fantastic to have.
http://www.brewersperformance.com/products.asp?id=237
that is a good starting point and you can save a lot buying parts from fellow FABO members via the used parts thread here (I did)
1: A-833 trans
2: 10 1/2 bell housing
3: 130 tooth flywheel
4: clutch pedal assembly
5: Z-bar and clutch linkage
6: clutch
7: floor hump
8: shifter
9: an engine with a crank machined for a pilot bushing
