skep419
No show, all go!
I have another thread started with the rest of the build. Link below. Got the transmission apart and found some issues.
found some issues.
The chunk missing? It's only job is to hold the snap ring. So it should be ok right?
Has anyone bought a rebuild kit from Brewers ? or is there a better option
Good thing you tore the transmission apart and found that before you put it on your car!
I am hoping my 833od looks better than that, but the noises it was making the first time I drove it, I don't know, I may need to just pitch it. I guess I will take it apart first then order the kit if it salvageable.
25 miles from home. Old coworker. Was out of his old volare dirt track car.
It supposedly shifted perfect when pulled 10 years ago. So did the last one I took apart. Heard mixed thoughts on the brass forks but cheap insurance I guess. Thanks.
I forgot you had that other box. If it has steel shift forks you can use those. I have broke those brass ones several times.
EDIT: I went and looked through your pics again and that is what they look like after using ATF in a gear box. Don't want to jack the thread, but beware of that. All that metal transfer and all that. It it possible it was run low on lube as well. The end result is usually the same.
