4 speed trans
purpled
Ia
Got a 4 speed trans in trade, what is it???? The trans tail number is: 97477-2 The front housing has the numbers C95664; C97372; 1X23x67; the retainer spline number is C94798; the tail housing measures 13". I counted 23 splines. Let me know if you know what it is A-body, or B-body. It is complete Hurst shifter, shifting arms, front retainer and the spline moves freely. thanks
$900 with shifter and linkage...wish I was closer
If you still have it then..I will definitely take it
Input shaft is broke off. It is a 67-70 a-body 4spd trans. I would need a rebuild. Shifter mechanism is a factory hurst. $ 900 - as is would need to see it with the side cover off and feel it turn
Need a picture of the other side, there may be a pad there that is milled flat around 3/4" X 3" with numbers on it, that will tell you what it came out of...
