All Prices are plus shipping. Located in Toronto, Canada but can ship from Buffalo, New York as well
2 1969 A833 23 spline A-body 4 speeds. 2.66 first gear ratio, non overdrive transmissions. 23 spline input, 30 spline output. Rebuilt and ready to run with zero problems. Bolt on your shifter and go! $400 each
Lakewood Scattershield with block plate for small block mopar to A833 4 speed/Doug Nash. Comes with a reinforced clutch fork bracket (factory supplied will bend with any sort of performance clutch). Never had an explosion in it, sandblasted and painted, just needs some cleaning. $250
Used Centerforce Dual Friction 10.5 clutch for 23 spline A833 transmissions. Disc still has plenty of life left. Clutch still works great. A little dusty but nothing that cant be cleaned- $150
Billet Steel 130 tooth flywheel for 6 bolt crank flange. Internal or external balance (bolt on weight). Also drilled for 5 speed clutch assembly. $75
Black used 67-76 A-body 4 speed Carpet. Bought new two seasons ago, still in amazing shape. Was always kept clean and used floormats to help preserve it. Good amount of material left along the sides to get a good fit. $65
4 speed hump for 67-76 A-body- Used and in good condition. Still in car. $60 or trade for an automatic floor hump cutout of the same size
