JGC403
What master cylinder are people using that have disc brakes at all 4 wheels?
I'm using the stock unit with a Wilwood adjustable prop valve in line for the rear
Strange Engineering light weight Master. Got it from Mancini Racing.
strange engineering light weight master. Got it from mancini racing.
Didn't see any by strange.
http://chucker54.stores.yahoo.net/24whdibrmacy.html
Good luck with Master Power....I run an MP factory style master with 1.032" bore plastic tank unit.
Sarcastic...
I am installing a Master Power 4 wheel disc kit right now. The kit comes with a stock style 73-76 A body master cyl and proportioning valve. The instructions that come with the kit say to disassemble the prop valve and remove the guts, turning it into a distribution block. Then they recommend adding an adjustable prop valve in line if you experience the rear brakes locking. I will be calling them soon for clarification. Good tech line guy there!
if they say you might need an adjustable prop valve then why use the stock prop valve turned distribution block at all.
just run a brake line from the MC to a T fitting for the front lines and run the rear line straight to an adjustable valve and sell the original prop valve to somebody who needs it. its a much cleaner arrangement and adjustable prop valves are pretty cheap from Summit.
