furrystump
- Joined
- Nov 13, 2004
- Messages
- 2,626
- Reaction score
- 2,362
Crank
Something I learned somewhere years ago, though I recall the petcocks seizing up after some time. This time I used antiseize on the threads so hopefully whenever the time comes to drain the block they actually work!
Happy with the motor, ball honed the cylinders and new bearing/rings/pistons. Hopefully get another 700 runs out of it.
When you think about it, how many times does anyone need to drain the block? It's handy when flushing things out good, a mess either way.Well, I pondered the idea over and over. Today, I went ahead, jacked the motor up, removed the motor mount, removed the drain and put it back in.
I never thought of putting a radiator drain plug on the block. Great idea. I am dreading removing the motor mount on the pass. side to get at the drain
Can you recall what the cam spec's are? Didn't they use a milder cam on the earlier versions vs. what they use now?As delivered the motor ran 12.99 in a 3645lbs car. With tuning and learning to drive muffler/gear change it got down to 12.47 with no changes to motor After changing back to stock intake manifold and ported x heads eddy 800 cfm thunder and different cam it ran 12.10 113mph right before I tore it down.
That's pretty good numbers.....113 MPH at 3600 lbs... sounds like it makes as much power as one of those "530" HP "mrl performance " enginesAs delivered the motor ran 12.99 in a 3645lbs car. With tuning and learning to drive muffler/gear change it got down to 12.47 with no changes to motor After changing back to stock intake manifold and ported x heads eddy 800 cfm thunder and different cam it ran 12.10 113mph right before I tore it down.
I think the early versions 2008ish made a touch more power. I can check the original cam when I get home. Looking at them now, mine came with BG, 825 cfm mighty demon, h beam scat rods, and forged ICON pistons. Now it has hyper pistons, i beam rods and holly 750. My Dyno sheet says it made 467hp and 510ft lbs. which seemed about right. They ran it with headers while i run stock 340 exh manifolds. The engine had definitely been run before I got it. The one thing that bugged me was I like the kevco oil pan that was on it, but the dip stick missed the oil in the baffle and the crank snapped it off. The pan has a plug to determine when its full so no biggie to me. Also the drainfor the pan is outside the sump area so it leaves about 1/2 a quart of oil in it when doing and oil change. I just welded in another drain in the sump area.Can you recall what the cam spec's are? Didn't they use a milder cam on the earlier versions vs. what they use now?
Must be the camera angle or camera used? I gasket matched and tapered down into the runners about two inches or so, radiusing the roof of the runners for a nice curve eliminating the pronounced angle change as they originally tapered to the 318 small port opening. And rounded all corners from the plenum into the runners, removed lumps etc. Spent a lot of time on it.Likewise,as above... Never seen a SBM Action Plus,that large before,,,How much work ,done....? SURE LOOKS LIKE A STEALTH .....
Not yet, engine in, waiting on torque converter and flexplate to arrive, just finished putting the trans together, that'll all go in asap, then doing the exhaust, wiring, throttle, etc.So is this thing burning tires yet??
Do you have to wiggle the engine and cherry picker through the door? Or lower the body onto the k frame? wow that's tight in there!Not yet, engine in, waiting on torque converter and flexplate to arrive, just finished putting the trans together, that'll all go in asap, then doing the exhaust, wiring, throttle, etc.
