younggun2.0
nice work. sure beats getting bent over by 4secondsflat.
I don't know. Seems to me that the 69 Jet is small. I ran 76's and 84's in the rear on my 750 on my brown car. It was a Demon though. Maybe at light crusing it is ok and as you put your foot to it a bit you are tapping a hair on the secondary's and that is richening it up? Just a thought to toss around. I would almost put the bigger PV back in it and up the main Jet size a bit in to the 72-76 range and see how it acts.
I have a Holley 850DP for the stroker going in the scamp has 80's in the front and 90's in the rear with a 6.5 PV , the guy I bought it from was running it on his 408 Stroker and said it should be pretty close as it is for mine. We will see hopefully soon.
I will be tuning with a Wideband also and this stuff is all new to me using one.
What vacuum does it pull on the highway?
You may need a higher number power valve so it opens earlier.
I'd put the timing back to where you had it and tune it there. If it's not pinging under load, run it there.
I'll try to get a vacuum reading while driving this weekend. I backed off the timing because i think it was pinging under load but that may have been caused by the lean condition.
Which 750DP do you have? Adjustable air bleeds?
If yes, go up .003-.006 on the idle air bleeds, outers. Readjust you mixture screws and see how the cruise reacts. It should lean it a little.
Usually when the mains start to activate you'll see a decrease in A/F reading. If it's still getting leaner, you're likely still on the IFR/transfer slot circuit.
