tiller02
KillerSwinger
I am selling my 408 small block. Built fall 2009.
1992 magnum block
scat 4" stroke crank
Scat forged i-beam rods
Diamond flat top pistons (11.8:1 compression)
total seal rings
Engine Pro main, rod, Cam bearings
Fluid damper
cloyes double roller timing set
Cometic head gaskets
Edelbrock performer rpm heads (gasket matched w/ light porting)
Smith bros pushrods
Comp 1.5 ratio shaft mount billet roller rockers
comp hydrolic roller lifters
Comp Cam
242/248 Dur@ .050, .3660/.3630 lift @ .050, 112° lobe sep. 549/544 gross valve lift
Comp valve springs, retainers, keepers, locators
ARP head studs
ARP bolts used throughout
melling hv oil pump
Edelbrock Super Victor intake
MSD Pro Billet distributor
bronze dist gear
Taylor wires and looms
New ngk plugs
Holley 750dp mech secondary manual choke (rebuilt this spring)
Mopar MSD 6 Ignition box
Blaster2 Coil
Adjustable rev limiter
Moroso fabricated aluminum valve covers
Always ran Joe Gibbs XP5 full synthetic oil, changed twice a year.
stored in climate controlled building.
Motor comes with everything from Carb to pan with ignition, so all you have to do is set it in, plug it in and go.
motor has about 60-70 passes on it and maybe 1000 miles of street use.
Ran a best time of 11.67@115 in my 3450lb '70 dart swinger. Runs flawlessly. Selling so I can build a twin Turbo fuel injected small block for the car. I'll also throw in the Hooker super comp headers that are on the car.
Located in grand rapids, Michigan
Asking $4800
Thanks,
Chris
1992 magnum block
total seal rings
Fluid damper
Smith bros pushrods
Comp Cam
ARP head studs
melling hv oil pump
bronze dist gear
New ngk plugs
Blaster2 Coil
Asking $4800
Thanks,
Chris
