408ci small block
tiller02
KillerSwinger
Grand Rapids, MI
Rating - 0%
0   0   0
I am selling my 408 small block. Built fall 2009.
1992 magnum block
scat 4" stroke crank
Scat forged i-beam rods
Diamond flat top pistons (11.8:1 compression)
total seal rings
Engine Pro main, rod, Cam bearings
Fluid damper
cloyes double roller timing set
Cometic head gaskets
Edelbrock performer rpm heads (gasket matched w/ light porting)
Smith bros pushrods
Comp 1.5 ratio shaft mount billet roller rockers
comp hydrolic roller lifters
Comp Cam
242/248 Dur@ .050, .3660/.3630 lift @ .050, 112° lobe sep. 549/544 gross valve lift
Comp valve springs, retainers, keepers, locators
ARP head studs
ARP bolts used throughout
melling hv oil pump
Edelbrock Super Victor intake
MSD Pro Billet distributor
bronze dist gear
Taylor wires and looms
New ngk plugs
Holley 750dp mech secondary manual choke (rebuilt this spring)
Mopar MSD 6 Ignition box
Blaster2 Coil
Adjustable rev limiter
Moroso fabricated aluminum valve covers
Always ran Joe Gibbs XP5 full synthetic oil, changed twice a year.
stored in climate controlled building.
Motor comes with everything from Carb to pan with ignition, so all you have to do is set it in, plug it in and go.
motor has about 60-70 passes on it and maybe 1000 miles of street use.
Ran a best time of 11.67@115 in my 3450lb '70 dart swinger. Runs flawlessly. Selling so I can build a twin Turbo fuel injected small block for the car. I'll also throw in the Hooker super comp headers that are on the car.
Located in grand rapids, Michigan
Asking $4800
Thanks,
Chris
I'll bump that one to the top. Great engine and a great deal to boot. Good luck with the sale and keep us posted on the turbo build. toolman
That is indeed a good deal. Try building that engine for near that and it is proven.
Gday Chris , can you tell me what trans and diff ratio you ran those times with?
thanks Ben
I have over double my asking price in parts in this motor. Thanks for the bumps guys. I hope it finds a good home. Had a lot of fun with this setup
I havnt used my pistol in a while and the bank is not far from me hhhmmmmm... Lol jk I wish I had money to buy it
Hello All:
I recently bought this engine.
I am refinancing my house next month to take advantage of the good interest rates (You may have noticed I've been blowing out a lot of parts lately). I would like to have the cash I spent on this back so I can pay down some extra mortgage while refinancing.
If someone wants to buy it before the refi, I will sell it for what I paid, and include a swanky engine cradle.
If the refinance happens before it sells, I'll be keeping it.
Thanks
Steve
