iw378
Well ?Me too. Waiting on cam specs.
The CFM per RPM was dropping quickly by the time it crossed 4K, not enough cam for big HP numbers, & I woulda opted for 1.6 rockers Myself at least on the intakes.
I agree w/longarm, I'd like to see a 650DP pull, and the torque curve.
Looks pretty good to me. I think you did exactly what you were trying to do.
Perfect engine for my "Towing Dakota."
Tow the race car to the track, tow what it ate off the track.... race around town with it.
My guess here(from reading his previous posts) is that he knows exactly what the hell he's doing. I'll wait for the punchline before I tell him how to do his job.
Well ?
Also notice those 1 5/8 - 3" headmans holding their own through 500 Hp/tq with 4" arm and the small lift cam.
I'm not surprised, actually, saw this with my own 410.
Thank you RAMM for another very interesting and light shedding post. I always enjoy reading your stuff, always relevant and reaffirming.
Something's making the intake side struggle more than it should have to. I look forward to seeing the cam card.[/QUOTE
Agreed, I am kind of confounded by this. I have observed 580 HP @ 417 ci @ 10.5 comp with these heads. But diff lift, carb, cam , etc..... J.Rob
Well ?
'Sorry guys--I'm 43 and have 5 kids---when the wife t' hrows the signal I gotta capitalize!. J.Rob
*Notice the 30-31 degrees of timing*
Pretty impressive I thought 15.5- 16" idle was good.This engine was slated for someone-J.Rob
So now that we've seen the cam card... was it your choice to pick the Crane camshaft or did a possible customer supply it?
Why not try retarding the cam to 110-112 icl and maybe 1.6 rockers on the intake to reach your goal?
Given we don't have the full flow test including the test bore used... My take... The combination of a 300cfm head, 1.5 ratio rockers, 2.08 intake valve on the 4.03 bore, and cam with (very) limited lift are all adding up to what I see as a dip in the ability of the intake tract to properly feed the engine at WOT as the rpms climb. Valve shrouding does have an impact, especially at low lift. If the heads flow well at higher lift there's usually a sacrifice in off-the-seat and low lift ranges. Then the intake valve is opened against the cylinder wall and not far enough to really let the unshrouded areas make up for it. It's making "good power" as it sits on the dyno and not knowing anything else about the intended use or owner. Given the numbers produced for them it's probably going to be fine. In my opinion I think the heads and camshaft choices could have been a better fit in this case due to the bore size but my truck doesn't rev over 4K even when I'm using it hard so the question of "does it matter" comes into play.
RAMM, what is the engine going in?
IMO, if the car is heavy, (normal car weight and loaded from the factory) and the owner just wants a powerful reliable daily driver, this engine fits the bill real nice I think.
It still has tons of head room for growth and that's not a bad thing. Taking maximum advantage is t allways the goal and nor should it be.
As I mentioned earlier, this would be a smokin kick *** engine in a small Dakota truck or even in a well equipped A body.
Oh! How did a stub stack do?
Until yesterday I have never seen an air cleaner assembly match or beat the air turbine which is essentially a velocity stack. Usually an air cleaner will knock 6-10 HP off. We tried all sorts of combos just minutes apart. This 4 hole deal was the worst-which did flow a lot less than a bare carb. J.Rob
