416 Stroker Kit Question
OK, so the stroker kit is finally on the way. I had to wait a couple of weeks since I needed the kit with .040 over pistons and the manufacturer was out of stock. Anyways, it is on the way now. I have ordered and received the Edelbrock heads, they sure look good.
I have contacted Comp Cams and they recommend the XE284H cam. Any inout or thoughts on this cam with my combination. I will relist the combo so you don't have to scroll back through this thread.
340 block bored .040
Stroker kit with Cast crank. Final displacement of 418 cu in with 10.3 compression ratio. 2900 lb Duster, 3.23 rear and an Edelbrock Air Gap intake.
