1965fish
If you're not interested or have negative comments please move on.
Thank you
416 cubic inch, W-2 Batten aluminum head engine. Price is $9500 carb to pan. It was just freshened up. Engine specs are: 340 block .030 over (1972) • Eagle forged crank – 4340 340006123 • mains and rods are std/std. • Clevite MS540H Main Bearings • Clevite Engine Parts CB-481HN - Clevite H-Series Rod Bearings • Eagle H beam rods - 6.123" 4340 H-Beam, Chrysler Small Block, 7/16" Arp 8740 Bolts. • ATI Super Damper. • Ross pistons (Chrysler ‘A’ Block: 340 – Dome Top: 4.070 Bore – 4.000 Stroke – 4.20CC – #99788) • Total Seal Piston Rings CR7590 35 - Total Seal CR Classic Race Piston Rings • 13.1 comp with .060 Cometic head gasket • Batten w-2 aluminum cylinder heads, rectangular ports, ported by Shady Dell 2.125"/1.60" valves, flowed 320.9/I and 222.5/E @ .700 • ARP Head Studs. • Harland Sharp 1.5 ratio Roller Rockers with shafts and stands. • INDY 360-I4-3R (fits 360-1) Manifold modified for 4500, rectangular ports, port matched to heads. • Lunati Drag Race Solid Roller Cam - Chrysler 273-360 302/310 #40200914 ( Advertised Duration (Int/Exh): 302/310; Duration @ .050 (Int/Exh): 273/281; Gross Valve Lift (Int/Exh): .640/.640; LSA/ICL: 106/100) • Comp Cams Endure-X Solid Roller Lifters for Chrysler V8 273-360, .904 (828-16) • Smith Brothers 3/8” push rods. • Stef's extra deep Oil Pan. • Melling M72HV Oil Pump 1050 Quick Fuels Dominator.
Engine is located in Bowie, MD
Thank you
