That would turn it into a pooch!
Depends on direction. If it advanced it. Probably not a big deal. Retarding, it is not going to be happy in most cases. And the almost never go advanced... LOL
HP is low for sure, and the torque is shy of potential also. A stock 360 magnum long block with a mild street cam/air gap and 750 DP will make 340 hp pretty easy
Well the intake and carb helped some but it is still lacking. Made 480ft lbs and 396 hp. I will put the motor in the car and then pay for a chassis dyno as in this session that I paid for I only have got 4 pulls. The cam was supposedly installed straight up.
What did the cam grinder recommend install at?Well the intake and carb helped some but it is still lacking. Made 480ft lbs and 396 hp. I will put the motor in the car and then pay for a chassis dyno as in this session that I paid for I only have got 4 pulls. The cam was supposedly installed straight up.
I haven't read EVERY post, but I don't think so...Did yall get a cranking psi number?
OK, one thing jumps out at me immediately: it's nosing over. Torque peak is 4K, it's down 30ft-lbs at 4500 and 60ft-lbs at the 5000RPM power peak. It loses 100lb-ft in 1400RPM.
Clearly, something is choking this engine. My first question is one I haven't seen, though I admit I haven't read all 6 pages of posts: how big were the headers? I wonder if the shop's "SB Mopar" dyno pipes were small-primary. I think this beast needs decent-sized (1 3/4", maybe 1 7/8") header primaries.
These are my Doug’s headers and are 1 5/8” primaries.OK, one thing jumps out at me immediately: it's nosing over. Torque peak is 4K, it's down 30ft-lbs at 4500 and 60ft-lbs at the 5000RPM power peak. It loses 100lb-ft in 1400RPM.
I was gonna say, they look just like the Doug's I've seen, and The Patriots ( made by dougs)...These are my Doug’s headers and are 1 5/8” primaries.
I’m thinking valve springs. IDK for sure.My guess at this point, you have a valve train issue.
spike drop spike drop spike drop... equivalent HP at 4400 and 5000 rpm, yep totally normal. NOT
Something isn't right for that to be consistent through the pull.
It ISN'T the headers...
What cam do you recommend?just another over cammed stroker engine
