X2 Polys aren't a bad design.That's badass. But no surprise.
impressive...but not a poly
not to be a jerk about it, and definitely not knocking their build, but thats a LA engine, with poly heads and a chevy intake, but still a LA engine
on the plus side, i like the adaption of the ford headers, that may be useful to someone building a poly engine
Your splitting hairs on stupid things.
Poly heads on a LA block is demoting the build to a non poly?
Have you ever had the 2 blocks side by side?!?!?!
On that mention, I don't "Think" but I "Know" I'd take the HEMI.I think I'd take a hemi over that..I'll bet they got as much in that as the cost of a hemi..
nope, i have never seen the two side by side
but what makes it an LA or a magnum or a poly or a B or RB ?
its not the heads, though each head is designed for each block, it is the block
if i were to make hemi heads fit a magnum would i have a hemi or a magnum?
if i were to bolt 340 heads to a 318, what would i have?
that was the way i was looking at it
LolAn Edelbrock Victor Jr. manifold from a GM LS1 application happened to have ideal port spacing and provided the raw material. The injector bung bosses were machined from the mounting flanges, then the work of mating it to the W2-style intake ports began.
Interesting. Did Chevy rob the poly design for thier LS series?
My opinion probably ain't worth squat, but to be a poly to me, it should be a full poly.
Block and heads.
Jeff
Or strokers...???Hmm..same can be said for guys running 318's with 340/360 heads on them and claiming they're a 318..
It's a 318. If they claim 340/360 due to the head alone, a shrink is needed.Hmm..same can be said for guys running 318's with 340/360 heads on them and claiming they're a 318..
