1972orangebeast
Up for sale is a very rare piece that I have decided I will never build and want to see it get used. This is a true 1970 date coded 5-25-70 block and dont not have a serial number stamped on oil pan rail. The block has been fixed see pics, it was done at Columbus Col-Weld which is very reputable machine shop. You can see that its cost 2400 to fix correctly in 2007 and has been wrapped up and sitting inside the garage since. Also included with sale is a set of bare 1970 date coded hemi heads, valves, dual four barrel intake, and a true 426 Hemi crankshaft. $10k obo
Also I have a complete 383 hp motor, and 727 that was pulled out of a matching numbers superbee. Motor is date coded 8-7-69. Motor can be fired up to hear it run. Motor has low miles, you can tell when it fires up no smoke and doesnt miss a beat. Was going to use it in a project and went different route. You get everything that you see pictured, kick down linkage, 727, converter, HP Manifolds, front accessories, yoke etc. $3800 obo
Call or text Jeff 7403341189
Located in Central Ohio, can meet at Mopar Nats and take a deposit on it now.
