426 hemi flywheel to a 340 small block
RAW10101
1968 Barracuda
United States
Hey fellows, I got a 426 hemi flywheel (new in the box) that I never used but I am needing a 340 flywheel now. The question is will the Hemi flywheel work on the 340 small block?
And, besides the two extra bolt holes (which if you have an 8 bolt 340 crank that won't matter) IIRC the hemi flywheel is 143 teeth and the 340 is 130 teeth.
Where will you get a bell housing?
You can likely sell the hemi wheel for far more than a 340 one would cost............
