furrystump
- Joined
- Nov 13, 2004
- Messages
- 2,173
- Reaction score
- 1,783
I cut these put at 1/4” aluminum. Who knew I was lying for all these years. It is a 410
The stickers say 'super stock IV' not 'stage IV' so he's ok I guess.I think the OPs stickers are pretty cool...... but “stage IV” are BB heads.
^^^^^ plus u don't have to haul the stuff all over the place to get machine work and balancing done .
I trust my machinist, theirs...…… not so much.
its clean now
Mines a 427 4" stroker from BPE and 4.125 bore. Haven't fired it up yet.
My frankenstroker consists of a K1 4.125 from a member here. Used Callie's rods 6.2 and custom DDS pistons. Yield is 420.93 ci. DanBPE offers (Or at least did) as high as a 4.250 stroke. The 4.125 stroke actually fits better with less clearancing the block than a 4.00 stroke because of the longer rod and smaller rod journals.
And I haven’t done any dyno testing but all the research seems to indicate the 4.00 and the 4.125 make the similar hp, but the longer stroke makes more 20-30 more TQ.
I had some custom decals made for my 426 stroker small block. I used BPE’s 4.125 kit in my 340 block, but Hughes makes a 426 kit in a 360 block. I also have an edelbrock STR-12 crossram intake I will be putting on it this winter to complete the look.
Wow looks great , that cross ram intake is going to look amazing .I had some custom decals made for my 426 stroker small block. I used BPE’s 4.125 kit in my 340 block, but Hughes makes a 426 kit in a 360 block. I also have an edelbrock STR-12 crossram intake I will be putting on it this winter to complete the look.
Gracias! Couldn’t work it out on my phone. Can build sweet cars can’t rotate 90 degrees
Intake is on and Holley efi is plumbed and linkage is installed . Just need to wire it up and see how it rips.
They make an app for that.Gracias! Couldn’t work it out on my phone. Can build sweet cars can’t rotate 90 degrees
I liked the Holley system for a couple reasons. The FiTech 2x4 system tops out at 625hp. Which is probably enough for my combination but I am pretty confident it could be right on the edge. The Holley is good to 1200hp.Looks killer! Please keep us posted on the Holley system. I've seen good stuff about FiTech dual quads, but haven't seen much about the sniper dual quads. Going to upgrade end of this year...need help deciding who to go with. Thanks!
Yepcarburetor gold finish?
I don’t but similar setups are 575-625 range. Has a Hughes roller hyd roller and they did Stage 3 porting on the Edelbrock headsany idea on horsepower and torque ? that has to be the best looking setup I've seen
