[WANTED] 440 Block
Demonracer
71 Demon 00 Ram 16 Chrysler 300S 05 Caravan
Cleveland, Texas
I'm looking for a Std bore 440 block with the main caps. It needs to be reasonably priced & close to the Houston, TX area so I can pick it up.
Hello Demonracer I understand you want close to you but incase you cant find one close, im in SoCal and have a block with caps Standard Bore $500.00, shipping mite be expensive. Just giving you options, Good luck with your search.
The reason I would like it close to me is so that I can visually inspect the block. I don't want to take a chance of getting a block that is not usable.
I CAN TAKE TO THE LOCAL MACHINE SHOP IF YOU LIKE FOR SOME EXTRA CASH.
