I wouldn’t call that a “crack”.
To me, A crack implies it was once whole, and now the material has been over stressed....... and now there is a crack where the material failed.
I would call that more of a “fold”, where the material ended up with that small void during the forging process.
In any case, I wouldn’t use it.
I’m probably just cynical....... but I’d prefer to buy rods from a source where that was a major portion of their business model....... not just one of thousands of items they sell.
Thats not to say you couldn’t have still found one like that from Eagle, Scat, K1, etc.
Well, obviously..... we know what they “should” do.
Let us know how it plays out.
I will not use this thing, I removed material to see how deep it goes. I will x ray the whole set because I'm curious. Choosing this brand was risky enough. Also if anyone wants to buy these, be prepared to do some work prior to install even if you don’t get junk like I did. Amazingly they measure out fine and were withing 1 gram off each other.I see what you did, but that's definitely not a place I'd remove metal, now you gotta balance all that out.
Good idea.I will not use this thing, I removed to see how deep it goes. I will x ray the whole set because I'm curious. Choosing this brand was risky enough. Also if anyone wants to buy these, be prepared to do some work prior to install even if you dodnt get junk like I did. Amazingly they measure out fine and were withing 1 gram off each other.
To be exact 6 were 805g and 2 were 804g.
Yes measurements were fine, oiling holes on small end needed de burr and machining on big end sides was not as expected. Also they are rough in hand and surfaces that you’d expect flat are not that great. Thing is that they were 299$ with 8470 arp bolts and comparing to LY rods they are very nice. I had bad luck I guess.Good idea.
I bought some speed master rods too, however mine are nearly perfect. They're honed as close to perfect as can be and mag'd just fine.
I however changed my build to go another step up on power and choose Molnar power adder rods.
But, I will be using the speed master rods in something street friendly probably another 470
Must've used some heavier peening material.More photos of these rods so you can see what you get.
I could have guessed Europe by that exhaust in the background , lol. Trans Looks good, hope it lasts for you too.Transmission is done for now.
It was not as expected, had 3 pinion planetaries and 3 clutch front drum.
I put 4 thin clutch plates and thinner snap ring in, tf2 kit, sonax servos and bolt in sprag.
Hope it lives thru 2022, once this season is over I will put 6 clutch drum, and 5 pinion steel diesel planet with 4 pinion rear planet. It will also get deep pan.
It’s just too much money to spend at once for all this and waiting time with shipping to Europe really sucks. Also I had bad luck recently and some packages were stopped by customs, I wasted few hundred in taxes.
Duster went thru some changes, still need to put port injected nitrous setup on but can’t find time.Oh yeah, really nice looking duster by the way
Dang, that's insaneA friend was drilling a counter weight on a BBC and found a bicycle chain in the crankshaft. Quality control must have been sleeping that day, damn Chinese parts...
Man, I really hope for you they'll do what's right.In the end we bought a set of Scat rods part # 2-440-6760-2374-990A. These have ARP2000 bolts. I had no problems using these in 1100hp nitrous fed big blocks. Overkill but if the owner of this decides to build 500ci, these will work no problems. I’m going to have them airmailed so hopefully will be able to resume work on the engine in 2 weeks instead of waiting 6 weeks for standard package.
In the mean time speedmaster want me to return the whole set. Explaining to them that shipping both ways will cost more than the rods is not making them decide to send me a single rod yet. At this point they don’t even want to sell me a single rod! I will update how this ends. So far it’s a major disappointment. I guess you get what you pay for service included.
Somehow I doubt they will respond to my emails any further. I’m already ignored on their Facebook.Man, I really hope for you they'll do what's right.
That sucks, sorry to hear that man.Somehow I doubt they will respond to my emails any further. I’m already ignored on their Facebook.
