NoahSewal
I have a 75 440 tv block with cast crank and factory internals. would a build with the UEM-KB237-060 pistons, 88cc chamber heads, a cam with 110 lobe separation .5 lift and 240ish duration at 50 on intake/exhaust be any good? will i have any issues or is there a better way to go. im holding off on the aluminum heads for now since they're upwards of 1,300 dollars. any opinions appreciated
