i have checked charging system and gauge is accurate. Im getting 13.9 to battery while running. You guys are correct it is internal regulated. I tested the battery and load tests fine. Im going to change the battery cable ( since its in the trunk ) and maybe that will help. And yes ALOT has been modified the previous owner did a number on the wiring ( changes color 5 times to still go to same component ). And since I put in the 440 its been interesting trying figure out all the wires.
This is the kind of info we need.
Here's the general premise:
1--CHARGE the battery keep it disconnected to remove the possibility of a vehicle leak and load test the battery
WHAT did it load test at, what amperage? What cranking amps is it rated at?
2--I'm assuming from your comments which need to be MUCH more specific that it sounds as if the starter is slow. AFTER (1) above is done, and you KNOW the battery is OK, then............
Check for starter CURRENT draw as well as excessive voltage DROP on the cables. Since it is now apparrent this is trunk mounted, this is even more important.
So beg borrow or steal the same type carbon pile load tester that was used to load test your battery:
3--Determine if the starter is drawing excessive current. You do that by cranking the engine, while monitoring battery voltage. The starter will sag the battery to some level after 3-5 seconds. What you then do is you put the load tester across the battery and crank in load until you again sag the battery voltage to the same level as when cranking. Then you immediately read the starter amperage right off the load tester. You'll have to get ahold of a rebuilder to find out starter draw if using a mini starter, I don't have that info.
4--A---At the same time, check voltage drop on the system cables and connections. To do this with a trunk mount battery, you'll need to "rig" a long wire, can by no 16 or 14 to reach from front to rear, with a way to attach to an alligator clamp. You will need two people
Clamp your long wire to the ground clamp at the battery. Run the wire up front, hook one probe of your meter to the end of the wire, and set your meter to "low DC" volts. Stab the remaining probe onto the engine block and crank the engine, ignition off, and read the meter while cranking.
You should read a very low reading, the lower the better. Post this reading.
4--B--Check the "hot" side next. Clamp your long wire to the POS battery clamp, up front hook the wire to one meter probe, and "rig" a clip to the starter terminal to which you hook the remaining probe. Crank the engine and take a reading while cranking As with the ground, you should read a very low reading, the lower the better.
5-- If it's easier to understand the two above tests can be done so: Clip your meter to the battery in the rear, take a reading while cranking. Move the meter probes to the starter terminal and engine ground and crank again. Subtract the two readings, and the result will be the total voltage drop from the battery up to front.
Don't 'assume' anything. I've seen deteriorated cables where they were soldered/ crimped into cable connectors. Speaking of which, anything which gets hot while cranking is a BIG clue. Crank the engine in the above tests, then run around and feel the battery clamps, the ground at the battery, the end terminals of any cables.
How is the battery grounded? To the body? How is the engine then grounded to the body? Or is the battery NEG cable run all the way up front
To repeat earlier, and what others have said, "about" 13.5--14V charging voltage means there is probably nothing wrong with the charging system.
If the battery was PROPERLY load tested by a good tester, this is the starter, cables, grounds, connections. If you have an extra (Ford style) solenoid and or disconnect switch, suspect them as well Once again, if any switches and relays are getting warm, ---trouble inside.
