440 external balance flywheel
Muswagon
Winnipeg
What are you guys using for flywheels with a cast crank 440? 130 tooth
You can get a steel billet FW from 440 source. I wouldn’t bother with anything else, unless you wanted an aluminum FW and I don’t suggest that.
I used to use neutral balanced flywheels for everything back in the day and the old Direct Connection race book used to give all the specs for material removal to balance for external balanced motors. I had done 360’s, 440’s and even a 400 with zero issues.
Cliff Ramsdell
Brewers sells flywheels for cast crank 400s and 440s, I have 1 I would sell but I see youre in Winnipeg, shipping would be a killer.
