440 in 67 barracuda
irelandmoss
Shenandoah, Pa.
I would like to put a 440 in my 67 Barracuda Notchback.
Is there anything I should know? I.E. changing k-member,
motor mounts, etc.
Thanks for any help.
I was thinking of doing it, but too much hassle.
I plan on a hot 360 that should have plenty of horsepower comparable to a big block and less weight.
go there. http://bigblockdart.com/ they can tell you what you need to do.
but like cudaspaz said, i would go with a hot small block. thats what i did. the brakes work better and the so does the steering wheel. i have a 360 in mine and its scary fast.
i would suggest a 400 block instead of a 440 block and use elephant ears and you'll be OK!!!!
heres our old 69 notchback with a 440.
