wazoo64
Just picked up a coronet with a built 440 but pinging and off idle hesitation. It's got a vacuum dizzy and specs below. Any quick tips to troubleshoot? Also, I'm curious if I should go MSD, aluminum heads with roller rockers. Would i see a big HP gain? Here are the basics.
Engine: 1964 440 cu.in (.30 over)
*balanced and blueprinted
*906 heads w/stainless valves, double springs and new guides/seals
*double roller timing chain
*10.9-1 KB pistons
*steel crankshaft
*HP windage tray and HP hi-performance oil pump
*street hemi (purple shaft) cam (284 degree duration)
*mopar high performance medium rise, dual plane intake manifold (M-1)
*edelbrock 750 CFM carburetor (Carter AFB)
*professionally built
*very strong and rated 500hp
*10.9-1 KB pistons
*steel crankshaft
