440dartsport
I am running a .030" over 440 with 10-1 comp. The cam is a Hughes solid .610/.614 lift with 1.6 Hughes roller rockers. Indy EZ-1 heads and Indy tunnel ram. My question is what carbs would you recomend? I was thinking 2 650 Holley double pumpers but maybe something bigger??? The car is a 74 Dart Sport with a 4 speed and dana 60 with 4.10's. It is going to be mostly a weekend street car with a few passes down the strip. If someone could post up some pics of there tunnel ram linkage and fuel lines set up, that would be great. Thanks in advance.
