megacab
Leglhi
Just wanted some opinions on which carb to use.Right now i have a King Demon RS on my motor with the 975 sleeves.Its on a Indy intake with a two inch Moroso adapter because the intake is still a 4150 pattern.After having it matched to the W-5's i couldnt spring for the extra to have it changed to a 4500.The biggest problem is the fact that it sticks six inches above the cowl and my six pac hood wont fit.My options are replace the 2 inch spacer with a 1/2 inch i have,or go to a 4150 carb.Seems to run fine with the big spacer,but man it sticks up there.Will that 1/2 spacer kill it?Thanks
