mopowers
I picked this up for a A518 swap, but turns out my non-lockup A518 takes a regular 727 yoke. This was used with a 46RE. Not sure if it'll fit later lock-up 46RH's. Uses a 7290 u-joint. $40 shipped from West Sacramento, CA (PP F&F, postal money order, or check). Or $20 local pick up.
If desired, I can include the 7290 weld yoke for a 3" driveshaft, but you'll have to cut off the weld and small section of old driveshaft. I can also toss in the old u-joint and c-clips (still nice and tight, but can use a a good scrub).
