Hey Guys,
I have a 46RH A500 transmission for sale. Pick up only in Hyde Park, NY.
I may be able to help deliver within 100 miles.
$250
Not sure of the year but it is a 93 - 95 out of a Dodge van.
Stamped numbers are PK5211832821235870.
Will need rebuild so it should be considered a core. No converter.
For those who do not know, the 46RH is basically a 727 three speed with an overdrive unit.
Makes a great swap behind an LA, Magnum or Gen 3 Hemi.
There are many threads on what it takes to install in whatever MoPar you have.
Thanks FABO!!
$250
Thanks FABO!!
