I'm building a 470 Bracket/NSS 68 Dart. Short block is a MM rotating assembly with 3.90 stroke eagle crank, Eagle I beam rods, Wiesco flat tops @ zero deck. The Max Wedge Stage VI heads were ported and built by Jim Laroy. I plan on running a Hughes Solid cam HUG HTL 7276 BS3. here are the specs.
Camshaft Technical Details
Intake Valve Lift 1.5
Exhaust Valve Lift 1.5 .620"
.629"
Intake Valve Lift 1.6
Exhaust Valve Lift 1.6 .661"
.671"
Intake Duration at .050"
Exhaust Duration at .050" 272°
276°
Lobe Separation Angle 108
Intake Opening at .050"
Exhaust Opening at .050" 31° BTC
69° BBC
Intake Closing at .050"
Exhaust Closing at .050" 61° ABC
27° ATC
Min. Suggested Cylinder PSI 225
Sweet Spot RPM 3300 - 7200
I'm going to use a single external Milodon oil pump set up.
With a max RPM of 6800-7000. My question is do I need to perform any of the oiling mods to the block. IE like restricting the oil to the lifters or restricting the oil to the rockers, etc .I figured now is the time to address these issues.
.629"
.671"
276°
69° BBC
27° ATC
