PRH
I've got a call out to our local flow bench operator and porter.
He's worked many Indy heads.
Me too.
Been a dealer for about 20 years.
If they are Morels you have a much better chance of success. Were they disassembled, inspected, cleaned and reassembled prior to being put in use?
Just a little reassurance maybe, the hydraulic roller lifters in my BBC were dead stable to 6700 on the dyno, and while I dont turn it that hard in the boat, it has been to 6200 many times. They are factory gm replacement hydraulic lifters. Good oil control and pressure is important.
****. Didn’t even think of that. What a shame.I’ve never seen a link bar(retro-fit) HR lifter that you can get apart(aside from the Comp evolution lifters).
The plunger hits the link bar rivet before it’s clear of the bore.
and I respect that.Me too.
You will be quite pleased dealing with Scott Koffel (Ohio shop) or Rich Koffel (Michigan shop). Very straight shooters, honest, and friendly. Rich does/did all my work as I was local to him. Now I'm in Florida....may have to make the long drive if needed!!Just a couple updates. Scott Koffel and I talked this morning when I dropped off the motor. He seems to be easy to deal with and knows what he is talking about. That being said, I am more concerned than ever about the hydraulic roller lifters. Mine are Trickflows purchased on 2021, so I believe are actually Morels. Scott relayed that they have had issues with hydraulic roller lifters on the dyno, but not the instability issues that others have mentioned. Basically lifter plunges getting stuck due mainly to tolerance issues with the lifters. He said this was mainly with comp hydraulic roller lifters, so I am keeping my fingers crossed that I won't have this issue. Motor should be ready for some pulls tomorrow.
Aren't the koffel guys the b1 pro-stock dudes ?You will be quite pleased dealing with Scott (Ohio shop) or Rich Koffel (Michigam shop). Very straight shooters, honest, and friendly. Rich does/did all my work as o was local to him. Now I'm in Florida....may have to make the long drive if needed!!
I hope you are as pleased with the results!
yepAren't the koffel guys the b1 pro-stock dudes ?
Good ****
While dropping off my engine this morning, they had one of there dragster motors sitting in the shop. B1 heads with a huge blower. The exhaust ports on heads are huge.Aren't the koffel guys the b1 pro-stock dudes ?
Scott has been great to deal with.You will be quite pleased dealing with Scott (Ohio shop) or Rich Koffel (Michigam shop). Very straight shooters, honest, and friendly. Rich does/did all my work as o was local to him. Now I'm in Florida....may have to make the long drive if needed!!
Yeah, this is the 3rd big block mopar that we have had rear seal issues with. At least it was found before I had it all in the car, which is one of my reasons for having it run on the dyno.Rear seals…….I feel your pain.
Hope you get it sorted out.
If it's the one for their car, I've seen it go 3.70's at Milan Dragway.While dropping off my engine this morning, they had one of there dragster motors sitting in the shop. B1 heads with a huge blower. The exhaust ports on heads are huge.
AwesomeWhile dropping off my engine this morning, they had one of there dragster motors sitting in the shop. B1 heads with a huge blower. The exhaust ports on heads are huge.
Oh, it's going to rip, those numbers are pretty close to mine if I recallAnother new update. Rear Main seal is fixed and Scott made an initial short pull from 2,500 - 4,500 just to get a baseline. Initial numbers are 535 HP @ 4,500 and climbing and 642 TQ @ 4,200. This is with dyno fender well headers and carb. Can't wait to see what a full pull looks like tomorrow.
A picture of that plugged area would be great if you can.Couple more updates. Scott said it will probably take them most of today to get everything back together back together and sealed up. Scott is very knowledgeable on the rear main seal issues and said they are pretty common. He replaced the aftermarket Mancini Racing (MRE-223) billet main cap on the engine with a stock style and fel pro 2947 rear main seal. (said they have the best luck with this combo) Keeping my fingers crossed that this does the trick.
On a side note, I learned something about big block mopar cooling from Scott this morning that I didn't know. I am using a mopar aluminum housing with an electric water pump. Scott to a look inside the thermostat housing and said that I didn't have the bypass plugged. Never heard of this before (maybe this is common knowledge) but apparently there is a small bypass port inside the housing where the thermostat mounts. Scott said block this (tap and plug it) will increase cooling as it will force the coolant into the block. (He is going to do it my engine while it is there) Just thought this was interesting and makes me wonder if this could have been leading to the cooling issues on my dad's motor that we fought for a number of months when we first got his car on the road as he is running the same housing but with a high flow mechanical pump.
I'll get one when I get the motor back home in a few days.A picture of that plugged area would be great if you can.
