472 Ray Barton Hemi overheating
loganscuda
This/These
san antonio
I've been helping a buddy with his Hemi it is running about 210 degrees he has duel fans with a becool radiator seems run cooler without the thermostat in it. Ray Barton said it shouldn't get over 200. I checked the timing and it is right. Could he have an air fuel problem. He has duel carbs on it. I told him to pull radiator and have it checked out. Any ideas.
Ooooh that would be a good place to check never thought of had not noticed. I will check there should be signs of water marks if they are correct
210 is hardly over heating. I don't care what Ray Barton says.
If the heads are weeping change the radiator cap to 8-10 Lbs or as low as you can find.
