dave w
R1A Block with W2 Top End:
· 48 degree block
· 4 Bolt mains w/ ARP studs
· 9.2 Deck Height
· Rough Bored to 4.0395
· Uses Traditional Oil Pump
· Block has motor mounts
· Block has all mods done for oiling to run solid roller
· Block comes with sonic check sheet and is good to up to 4.125 bore
· 50mm cam tunnel with roller bearings
· Billet Comp cam: 252 int @ .050 258 ex @ .050 .674int/ex w 1.6 ratio rocker 106 lobe sep
· 48 degree un-ported W2 heads
· 15 degree valve angle
· 47cc chambers
· Ferrea 2.05 int valves with 1.60 ex valves
· Jesel Pro-Series 1.6 ratio rocker arms with tool steel shafts
· Isky springs with titanium retainers set-up for Comp Cam
· Correct Mopar 9.2 deck height single plane intake manifold.
All parts are in excellent condition and have been well taken care of. I have plenty of pictures of all parts and can email them to you. Everything listed for $3000 and I will split the shipping costs anywhere in the 48-states. This is a great deal! PM me Thanks!
· 48 degree block
· 9.2 Deck Height
· 47cc chambers
