65TerrorCuda
So while doing my green bearing conversion I noticed that it's nearly impossible to rotate my axles backwards with both wheels off the ground. I'm talking prybar hard, I can't physically do it without leverage. Forward is a bunch easier but still draggy. Trans is in neutral with driveshaft connected.
I do have a locker so both axles are turning the same direction, no differential action.
Gear noise I get at 25 and 33 mph on cruise and accel, goes away on decel. Used gearset, probably factory.
Here's the weird bit, cornering I get a loud whine from the rear end even with new axle bearings. Same as before green bearings. Front wheel bearings are all new.
Brake drums were off so no drag there.
Any ideas please let me know. I'm guessing worn R&P and/or carrier bearings. Hoping it's just a pinion depth adjustment lol
Edit: there were little metal flakes, 1 or 2 mm, that were copper-ish on one side and silver on the other in the lube sitting in the axle
