[FOR SALE] 496 c.i. RB SHORT BLOCK
das858
Nebraska
FOR SALE : 496 cubic inch RB short block ,040 over 1970 440 block , deck squared, mains align honed , ARP Main studs , NOS Mopar Kellog crank with 4.15 stroke , nitrided , aluminum BME rods , BRC flat top zero deck pistons , Total seal piston rings , Balanced rotating assembly , $4700.00
Can you post piston part number?
or detailed specs?
the wrist pin diameter is.990 , spiral locks , .120 wrist pin wall thickness, 5/64 compression rings , 3/16 oil rings , total seal brand rings
The pistons have # 10417 stamped on the bottom of the wrist pin boss
