roccodart440
- Joined
- Apr 19, 2010
- Messages
- 6,812
- Reaction score
- 3,595
Nice work. I have the same rear and tire size under my dart. You'll be happy with that setup and have a little more clearance than I do.
Thanks guys I appreciate it.
I'm from the school of you can never have too many grounds. I also have one going from the battery to the roll bar. Its not in the picture. The one going forward will bolt directly to the engine.
I'm going to be using a Ron Francis harness and he also recommends a lot of grounds.
You are correct, it does add a few pounds but that's one that I'll live with.
Ted
A quick note - on the torque boxes... You did remember that you have to cut a hole in them, right? Otherwise you can't tighten the front spring hangers at the body.
wonder if anyone has ever thot about a crankscraper that is thicker, to double as a girdle ?I was able to put some more time in on the Demon over the past week.
I cut out some sheet metal pieces to fill in the speaker holes where the roll bar is going through. I figured it would be easier if I eliminated the oval shape so I cut it to be almost square. I made the 2 piece with a flange to connect the two.
I also made an adjustable brake plunger.
We're planning on getting started on the engine some time this summer so I called to order a crank scraper from Ishihara-Johnson. They sent me this template to cut to fit my crank and rods. They told me that there's too many odd-ball cranks out there now and doing it this way takes all of the guess work out. I think that this is a smart way to go. I would rather spend an hour doing this than getting a cookie cutter part off the shelf. But that's just me.
Until next time.............Ted
Wow nice build Ted. What are the specs on the Low Deck..?
I have an eagle forged rotating assembly for it. The plan is to run it on E-85 so I'll be targeting a static compression of 12 to 1. I want to run a set of the new Trick-Flow 240 heads.
I have a dominator for it but it needs to be converted to e-85 specs. I'm thinking of running an M-1 intake.
double that !Very nice!
