[WANTED] 4inch stroker crank
BVoelzke
North Jersey
I need a 4 inch stroker crank for a small block , 340 mains , no cast or Eagle please also looking for a rocker setup for Indy 360-1 heads , T&D , Harland Sharp, or Hughes
Hello,
I am a Molnar dealer and can get you a 4.00" stroke crank with 340 Mains and Chevy (2.100") rod journal. There are none available in a Chrysler rod journal.
This would be Molnar part # 340-4000EB6F
Total cost shipped to your door in New Jersey would be $979.00
Thanks,
Tom
What are the pros of a Chevy rod journal? Just a more commonly available rod?
Staying with the same 6.123 length?
Possibly less expensive?
I have a set of Harland sharps for w2 heads if they are the same. Have less than an hour of run time on them.
Hello,
Thanks,
Tom
Thanks
Hello,
Thanks,
Tom
Molnar is a great choice
