340cudaman1
Member
I have a problem with my pedal bracket. The lower cross bar support has broken loose from the main bracket on the left side of the assembly (the horz bar that is below where the clutch pedal stop is). In order to repair, I need to remove the pedal assembly.
I have manual 4W drum. It appears the bolts from the assembly also secure the master cyl. for the brakes.
My main question is how to get the assembly out? Will I have to remove the steering column? If not, how? Any help would be appreaciated.
Thanks in advance.:-k
340cudaman1 (I use to have a 71 340 with a shaker)
