AliquippaWhere are you in Pa.?
YesAluminum bell?
2b103 or 8Is there a VIN or partial VIN on that flat pad?
Would you consider selling the bellhousing seperatly?Up for sale is an a body 4speed trans with bell housing. Located in 15001 $950
Yes not an over drive bell or trans. Small retainerSorry I see it's for a small block. But still for what size clutch? Also is this a matched set retainer to bell. Thanks again.
If you put the side lever in first gear and turn the input shaft 1 revolution and count the revolutions on the output shaft you will see a little over 3 or a little over 2 1/2. And is this for a a-body?
