I sent the box in to MSD to have them check it out
Msd will not suggest any changes to the files---liability issues was there answer
Yes map sensor connected
Stock ignition coils
O6 out of a durango--8,000 miles on it
I'm not rude at all,I posted here when these issues where going on and no help was here
So what your telling me is the timing chain/gears could not be off and cause excessive timing?? HUM
Any help on this is very much appreciated,Just don't tell me what I don't have,The more timing we gave it,the more it liked it that is a fact. Have you worked on one with a carb??
Before i took it to the Dyno tuner the car fell flat on its face at 4,000 rpm and then would recover and then go like a bat out of hell,This burp was removed when they bumped up the timing and changed the jets in the carb
I would be glad to post the ign. file How????
Thanks Steve
