- Joined
- Apr 18, 2009
- Messages
- 4,310
- Reaction score
- 4,901
Some of you may have seen my thread on FBBO, late model hemi into early b bodies, and now that I've been driving it for a few weeks I have this nagging question/problem/maybe nothing to lose sleep over it.
My temp is running at 210 give or take a few degrees. I first started off with the factory 203 thermostat and a 195 on 180 off fan temp sender. The fans would not shut off going down the freeway, so I bout another oe thermostat this time rated at 195 and switched to a 210 on 195 off fan temp switch. Now the fans cycle like they should and the temp is running 210, and it will go 215 or so and the fans will kick on, temp comes down to 210ish and then they shut off. They wont come on going down the freeway, but will cycle in town as they should.
I have a Northern radiator, dual 10 inch Spal fans, have flushed the block 4 times, and always used new coolant 50/50 mix. Should I be concerned or just drive it and enjoy eating unsuspecting ferds/chebbys? Any comments or thoughts would be appreciated.
