Sorry. Early a body but I believe if it fits a 67 up it should fit. I just didn't know if they ever put the 5.9 in a pass. car.You don't say what car you're putting it in, so I'll make some assumptions. Use an A body 360 pan and pickup ('72-'76) with same year gasket/seal set, and matching dipstick and tube.
No, they never put Magnums in pass cars. You need to use the 360 pass car pan and associated parts for that. '72 and up will work, there weren't 360s before that. (273/318/340 pans don't work.)Sorry. Early a body but I believe if it fits a 67 up it should fit. I just didn't know if they ever put the 5.9 in a pass. car.
View attachment 1715809692I ended up getting the truck oil pan and a360 passenger car oil pan fabrication using the correct magnum pan up top the car pan on the bottom. I can use the one piece magnum 360 gasket and no leaks. I just go off the freeway no leaks
