younggun2.0
starting to pick up parts for my junk yard 5.9 magnum engine. here are my questions?
is the magnum and 360LA oil pan the same?
what about oil pump and pick-up?
i need to swap the truck pan for a center sump car pan and while im at it i think i should install a new high volume oil pump and new pick up as well.
what about kick down linkage from the carb to my 904 trans? if this is too big a pain in the *** i will just run a manual valve body in the trans and be done with it .
