I got my 5.9 set up in the 64 dart with all the early model accessory parts, including the timing cover that has the timing tab on the wrong side for the marks on my balancer.
You can guess my problem.. I got it to run good by guessing and reading plugs, but I have no idea what the timing actually is.
To fix this, I was planning to get a pre-67 balancer for the 273 (with the correct timing marks) and have a balance shop mill it to match balance on the 5.9 Magnum.
Any thoughts?
Any thoughts?
