5.9 lifter ticking tapping noise SOLVED!
Slantsix64
Los Angeles
Hey guys wanted to post how I got rid of the ticking sound that was driving me nuts! Long story short I got a used magnum engine with low miles ported heads swapped cam and springs started getting a ticking sound that was constant.
Turns out it was ticking on the driverside 5th cylinder. The drivers side had a new reman rock auto cylinder head the other side did not. Had the original.
The push rod on that cylinder on the intake had a wear mark on it, turns out the casting of the new rock auto head was rubbing on the push rod causing it to tick. I used a carbide bit cleaned it up. Was real careful catching all the metal as best as I could. Started it up head the lifter pump up and the sound was gone :)
Hope this helps you guys I know @remytherat had a similar issue.
Good you got it fixed.
i hope you gave it an oil and filter change afterwards and plan another after a few hundred miles. any missed swarf is bad, but i don't need to tell you that.
glad you got to the bottom of the noise anyway. :thumbsup:
neil.
