67Charger
Member
Who makes an adapter block to get -8 and -10 fittings off the later model (1998) AC pump?
I've seen that one a few times, but always listed as GM. I suppose I should just grab one and see if it fits.
Hi 67Charger,
If you you end up getting one, please let us know if it works. I know myself and others either have the same question or will in the near future.
Thanks,
Travis
I used the hoses from the dodge truck that have the correct block that mounts to the compressor. Cut the ends that went to the condenser and evap and had an A/C shop put new ends on them.I ordered it today. I'll let you guys know...
That's the plan if this doesn't work. I received it in the mail as I was pulling out to go to work (second shift). I'll know more tomorrow.I used the hoses from the dodge truck that have the correct block that mounts to the compressor. Cut the ends that went to the condenser and evap and had an A/C shop put new ends on them.
easyrider
